Hola a todos, además de haber agregado una compatibilidad más que aceptable, la última versión de Vireio trae las siguientes novedades:
Improved Memory Scanner - Now uses multithread approach for quicker scanning.
Games will not start in Vr mode if the Vireio Perception Dialog is not open. Easier for playing normally without having to uninstall Symlinks / DLLs
Comfort Mode Added - As originally sugested by Cloudhead Games
Saints Row 2 Support
Saints Row 3 Support
Homefront Support
Deus Ex: Human Revolution Support
Deus Ex: Human Revolution Directors Cut Support - Please note if you have a choice we strongly recommend using the above version NOT the Directors Cut. The original is far better from a VR support standpoint.
Improved scanner compatibility in a few existing games (Outlast / Crysis / Far Cry 3 / etc)
Ability to Supress Vireio Hotkeys
PDF of Hotkeys reinstated to VP folder
VR Mouse - New implementation and look (Double Click NUMPAD 0 to toggle)
New Disconnected Screen View Implementation - Previous version had issue with cropping. New one should look better and fuller.
Sped up the Menu system - Should be now much more responsive.
Un pequeño gameplay hecho en obs con el vireio. Saludos
